Data Group with iRule 301 Redirects
All,
My client had Aaron Hooley assist with creating data group 301 redirects, however, the initial url product is being picked up by the apache http class. I tried doing http:class disable, but apache is still fielding the request causing a 404. I would imagine that the 301 redirect would kick in to feed weblogic. Any ideas?
Thanks,
Bryce
Data Group 301s
“www.foo.com/product.asp?SKU=100151” := “301 http://www.foo.com/store/product/duracell-battery-packs/100151”,
“www.foo.com/product.asp?SKU=11916015” := “301 http://www.foo.com/store/product/anna-griffin-jack-brag-book/1015158565?skuid=11916015”,
“www.foo.com/product.asp?SKU=11839797” := “301 http://www.foo.com/store/product/anna-griffin-jack-photo-journal/1015158514?skuid=11839797”,
Existing iRule
if {[set code_url [class match -value -- [string tolower [HTTP::host][HTTP::uri]] equals datagroup301s]] ne “”}{
HTTP::class disable
HTTP::respond [getfield code_url " " 1] Location [getfield code_url " " 2]
HTTP Classes
ltm profile httpclass /Common/Weblogic {
app-service none
defaults-from /Common/httpclass
paths { glob:/store glob:/store* glob:/store/* glob:/qas/* }
pool /Common/Weblogic_Pool
redirect none
ltm profile httpclass /Common/Weblogic_STAGING {
app-service none
pool /Common/Weblogic_Pool_STAGING
redirect none
Existing Root Responder irule
ltm rule /Common/BBB_root_res {
log local0. “Request_uri: [HTTP::uri]”
if { ([HTTP::uri] equals “/”) } {
HTTP::redirect “http://[HTTP::host]/store/”
Sorry I’m a bit unclear especially about your reference to ‘Apache HTTP class’ plus your statement that a 301 redirect would ‘feed’ Weblogic. Can you try and re-phrase the problem description please?
Steve,
Hard one to explain, we are using http classes, so I pretty sure the new data group 301 redirect rule is not working due to the http classes. Apache http class is the catch all /* to port 80, Weblogic httpclass expressions are /store* and /store/* . When I try going to www.foo.com/product.asp?SKU=100151 I am getting a 404 to apache. 301 redirect data group is not redirecting to 301 http://www.foo.com/store/product/duracell-battery-packs/100151. I can go directly to http://www.foo.com/store/product/duracell-battery-packs/100151 and it is picked up by Weblogic. Need help logging the 301 redirect irule to see if it is even getting hits on the data group. I would appreciate any assistance.
Thanks,
Bryce
All,
Meant to update the resolution a while back. Worked with Aaron to finalize the irule, we had to disable http classes and update the syntax.
Thanks,
Bryce
Final working irule configuration:
log local0. “[IP::client_addr]:[TCP::client_port]: [HTTP::uri] contains prod → [class match -value -- [HTTP::uri] contains datagroup301s]”
log local0. “[IP::client_addr]:[TCP::client_port]: Redirecting [HTTP::uri] to ([getfield $code_url " " 1]) [getfield $code_url " " 2]”
HTTP::class disable
HTTP::respond [getfield $code_url " " 1] Location [getfield $code_url " " 2]
log local0. “[IP::client_addr]:[TCP::client_port]: No match for [HTTP::uri] in datagroup301s”
HTTP::class enable
