Data group exeception
Hi I am new to irule. I am editing the SSL interception irule to include source IP address based bypass with data group. The data group is defined in the Common partition while the SSL interception is in the /Common/SWGUAT.app
ltm data-group internal SourceIPBypass { records { 10.61.88.0/24 { } } type ip }
Getting the following exceptions when I do syntax check:
Exception caught in LocalLB::urn:iControl:LocalLB/Rule::create() Exception: Common::OperationFailed primary_error_code : 17241203 (0x01071473) secondary_error_code : 0 error_string : 01071473:3: Create, modify, and delete commands are not valid for (by class: rule) while in the root folder.
Wondering someone could help me with the above syntax exception. Much appreciate.
Richard
Try removing /Common , i don’t typically reference the partition for the data group
got the same error after removed /Common. Any idea?
