Data Group Error
Hi everyone, Data-group list has more than 20million line. When i want to upload this file by using curl restApi, i got an error which is {“code”:400,“message”:“01070711:3: std::bad_alloc”,“errorStack”:[]}.
I should use this group in irule.
as a test why dont you cut the number of lines in half. most likely there will be a limit in the number of lines that can be read in a data-group.
or you can use multiple data-groups or consider using tables:
