Hello,
There are 2 variable, var1 and var 2 where var2 contains Danish characters. It looks like the Danish characters are distorted. Is there a setting within the iRule to enable a foreign language(Danish, in this case)?
Thanks,
Ratna
Hello,
Thanks,
Ratna
is this relevant?
iRules containing double-byte characters
Thanks for your reply nitass.
It looks like the iRule has no double-byte characters, but variables, which might be assigned a string holding Danish characters in UTF-8 representation.
Can you provide a sample original request and another example of how you’d like it modified? You might be able to use binary scan/format to modify the non-ascii characters.
Aaron
