CVE-2026-109619: PHP Use-After-Free Global State Flaw Enables Remote Code Execution— Mitigation Guidance using F5 Distributed Cloud WAAP
Vulnerability Overview
CVE-2026-109619 discloses a critical memory-safety defect in the PHP interpreter. PHP maintains various global state structures that temporarily reference request memory. Under certain conditions, this global state is not correctly reset between requests—or is repopulated after being reset—leaving dangling pointers to memory that has already been freed. Subsequent requests may then read from, or branch on, this stale state before it is fully re-initialized. Because multiple strategies can trigger the condition, attackers can exploit it to achieve remote code execution (RCE) against any service running a vulnerable PHP build.
The root cause is classified as CWE-416 (Use After Free), a class of vulnerability historically associated with reliable exploitation primitives in memory-unsafe languages.
Affected Products and Severity
Field Value
CVE ID CVE-2026-109619
CVSS Base Score 8.1 (HIGH)
Attack Vector Network
CWE CWE-416 – Use After Free
Published 2026-10-21
Last Modified 2026-10-27
The NVD lists the following affected products:
Vendor Product
PHP PHP
Siemens RUGGEDCOM APE1808 Firmware
Palo Alto Networks PAN-OS
Palo Alto Networks Panorama Virtual Appliance
Any application or appliance embedding a vulnerable PHP runtime is potentially exposed.
Request Path and Exploitation Flow
The following simplified flow illustrates how the vulnerability surfaces in a typical web-application stack:
Client HTTP Request
│  Web Server / SAPI   │  ← accepts request, allocates request memory
│  PHP Interpreter     │  ← processes request; global state points
│  (vulnerable build)  │     into request memory
       │  request completes → memory freed
       │  global state NOT fully reset ← BUG
│  Next Request        │  ← reads/branches on stale (freed) memory
│  (attacker-crafted)  │     → use-after-free → RCE
Because the attack vector is network-based and requires no authentication, any internet-facing PHP application running a vulnerable version is at risk.
Primary Remediation: Patch PHP
Patching is the only definitive remediation. Organizations should:
  • [ ] Identify all PHP runtimes in production (standalone, embedded in appliances, containerized).
  • [ ] Apply the vendor-supplied fix referenced in the PHP security advisory (GHSA-6wmf-4rv5-p3rp).
  • [ ] For Siemens RUGGEDCOM and Palo Alto Networks PAN-OS / Panorama, monitor the respective vendor advisories for firmware or software updates that bundle a corrected PHP version.
  • [ ] Validate fixes in a staging environment before production rollout.
Compensating Controls with F5 Distributed Cloud WAAP (XC)
F5 Distributed Cloud WAAP sits upstream of origin servers and can apply HTTP-layer controls that may reduce exposure while patching is in progress. The following capabilities are relevant but do not replace patching the underlying PHP vulnerability.
HTTP Protocol Validation and Request Enforcement
WAF service policies on F5 Distributed Cloud can enforce strict HTTP request validation—rejecting malformed headers, oversized payloads, or unexpected content types. Because the CVE relies on crafted request sequences that manipulate PHP’s internal state, tightening what the origin is allowed to receive can shrink the attack surface. Enforcement rules should be validated in a non-production environment before deployment.
Rate Limiting and Connection Controls
Exploitation of this use-after-free condition may require sending multiple sequential requests to the same PHP worker process. Configuring rate limiting and connection-throttling policies in Distributed Cloud WAAP can help slow or disrupt the timing-sensitive request chains an attacker needs.
IP-Based Access Controls
Where feasible, restricting inbound access to known IP ranges or geographies (e.g., North America–only policies) via service policies can limit the pool of potential attackers during the remediation window.
Important Limitations
No specific managed WAF rule or verified CVE-specific signature for CVE-2026-109619 has been confirmed in the supplied evidence. The use-after-free condition is a server-side memory-corruption issue; HTTP-layer inspection cannot guarantee prevention of all exploitation strategies. These controls should be treated as defense-in-depth measures, not substitutes for a patched PHP runtime.
All technical details in this article are derived from NVD and the publicly referenced advisories. Mitigation guidance should be validated by your security and engineering teams before production deployment.
References
