Vulnerability Overview
CVE-2025-5777 is a high-severity memory overread vulnerability (CWE-125) in Citrix NetScaler Application Delivery Controller and NetScaler Gateway. The flaw stems from insufficient input validation and is exploitable when the appliance is configured as a Gateway (VPN virtual server, ICA Proxy, CVPN, or RDP Proxy) or an AAA virtual server. Successful exploitation allows a remote, unauthenticated attacker to read sensitive data from device memory over the network.
The vulnerability has been publicly dubbed “CitrixBleed 2” due to its similarity to the original CitrixBleed (CVE-2023-4966). CISA has tagged the vulnerability as actively exploited, directing federal agencies to patch immediately.
| Field | Detail |
| CVE ID | CVE-2025-5777 |
| CVSS Base Score | 7.5 (HIGH) |
| Attack Vector | Network |
| CWE | CWE-125 — Out-of-Bounds Read |
| Affected Products | Citrix NetScaler ADC, Citrix NetScaler Gateway |
| Prerequisite Configuration | Gateway (VPN, ICA Proxy, CVPN, RDP Proxy) or AAA virtual server |
| Authentication Required | None |
| Known Exploitation | Yes — CISA-tagged as exploited in the wild |
Request Path and Exploitation Flow
The attack is network-based, requires no authentication, and targets HTTP/HTTPS endpoints exposed by the vulnerable Gateway or AAA virtual server configuration. The following diagram illustrates the high-level request path:
Attacker NetScaler (vulnerable)
│── Crafted HTTP(S) Request ──►│
│ (malformed input field) │
│ │── Insufficient input validation
│ │── Out-of-bounds memory read
│◄── Response with leaked ────│
│ memory contents │
Leaked memory may contain session tokens, credentials, or other security-sensitive data, enabling session hijacking or lateral movement — a pattern well-documented from the original CitrixBleed campaign.
Priority Action: Patch the Affected Product
The primary and most effective remediation is to apply the vendor-supplied patch from Citrix. Consult the official Citrix advisory for fixed versions and upgrade instructions:
- Citrix Advisory: CTX693420
No compensating control fully replaces patching the vulnerable NetScaler appliance. Organizations in North America operating NetScaler Gateway or AAA virtual servers should treat this as an emergency patch cycle given confirmed in-the-wild exploitation.
Compensating Controls: BIG-IP Advanced WAF
Where BIG-IP Advanced WAF is deployed in front of, or alongside, NetScaler infrastructure, it may help reduce exposure to CVE-2025-5777 by inspecting and filtering malicious HTTP/HTTPS traffic before it reaches the vulnerable appliance. The following capabilities are relevant:
Protocol Compliance and Request Validation
BIG-IP Advanced WAF enforces HTTP protocol compliance checks that can reject malformed requests — such as oversized or structurally invalid headers and parameters — that are commonly used to trigger memory overread conditions. Enabling strict protocol-compliance profiles on virtual servers proxying traffic to NetScaler endpoints can help surface anomalous requests.
Attack Signatures and Policy Enforcement
BIG-IP Advanced WAF maintains curated attack-signature sets. While no specific signature ID or confirmed CVE-2025-5777 coverage has been verified at the time of writing, signature updates should be monitored and applied promptly. Generic signatures targeting buffer overread and out-of-bounds read patterns may provide partial detection.
Custom iRules and Signatures
Security teams can author custom iRules or custom attack signatures that inspect the specific request fields associated with the exploit. Any custom rule should be:
- Developed based on published proof-of-concept details (see references below).
- Validated in a non-production environment before deployment.
- Monitored in transparent/logging mode before switching to blocking.
Checklist for BIG-IP Advanced WAF Operators
- [ ] Confirm attack-signature packages are current.
- [ ] Enable HTTP protocol-compliance checks on relevant virtual servers.
- [ ] Review published exploit research to inform custom signature development.
- [ ] Test any custom iRules or signatures in staging before enforcement.
- [ ] Enable request logging to detect exploitation attempts.
- [ ] Patch the upstream NetScaler appliance — WAF controls are compensating, not curative.
Limitations
BIG-IP Advanced WAF operates at the HTTP/application layer. If the exploit payload travels through a non-HTTP channel or through an encrypted tunnel that BIG-IP does not terminate, inspection may not be possible. Additionally, compensating controls should be considered interim risk reduction and do not eliminate the underlying vulnerability. All guidance above should be validated by qualified personnel in each organization’s specific environment.
