CVE-2014-6271 Shellshocked
It’s a good thing we are naming all of our vulnerabilities now; it’s easier to keep track of them. I haven’t seen an official designation for CVE-2014-6271, but Shellshock seems appropriate.
This new vulnerability may allow a remote attacker to execute instructions on your computer using a feature of the bash shell. A shell is a command line user interface with complicated features akin to programming languages. One feature of bash is to take user input from its environment. Unfortunately this environment can contain executable commands and in some cases can be manipulated by a remote user.
F5 has confirmed that BIG-IP’s web GUI is vulnerable to an authenticated user. We currently know of no unauthenticated exploits, either against the management interface or against the traffic interfaces.
We can enumerate through RedHat’s security blog’s list -- not a comprehensive list -- to look at some ways a BIG-IP could be exploited.
    •    BIG-IP does not use ForceCommand in sshd_config, so users cannot bypass ForceCommand.
    •    BIG-IP does not contain any bash CGI programs, although it is possible that some CGI programs spawn subshells.
    •    BIG-IP does contain mod_php, but the scripts are not vulnerable.
    •    BIG-IP does contain DHCP dhclient and is in theory vulnerable to a malicious DHCP server. This is the only known unauthenticated remotely exploitable vector at this time and is only vulnerable on the management interface. You may disable DHCP on the System::Platform page.
    •    BIG-IP limits the use of bash to authenticated Administrator level accounts. Non-Administrators only have access to tmsh and do not have access to bash.
We still do not believe the traffic passing interfaces of a BIG-IP can be exploited. Please protect your management interface and ensure that it is not exposed to the internet.
F5 will be patching CVE-2014-6271 on all BIG-IP releases. Sol15629 has been published.
Update: BIG-IP iRule mitigation has been posted. F5 LineRate has posted their mitigation. ASM has signature updates.
“At this point, we do not believe the traffic passing interfaces of a BIG-IP can be exploited.” Do you mean that traffic passing interfaces can’t be used to attack the BIG-IP appliance itself? Or do you mean the traffic passing interfaces won’t pass attacks to back-end servers?
And What about ASM? Is F5 Planning to release any signature for it.?
Daniel: This article refers to the security of the BigIP platform itself. The F5 ASM can block such attacks on backend applications when the proper signature is available. This signature can come from F5 or can be user specified. Another option is an iRule. Check this iRule: DevCentral - An F5 Technical Community
Can you confirm the User-Agent injection in the management interface? ashkan soltani on X: "Here's where it gets interesting: @F5Security BIG-IP web interface vulnerable to #bash #shellshock. (via @securifybv)" / X
We can confirm that the management GUI is vulnerable to an authenticated user. We will be patching this issue as soon as possible. “At this point, we do not believe the traffic passing interfaces of a BIG-IP can be exploited.” The attack will be passed to back end severs. We do not believe that the attack could exploit a BIG-IP directly through the traffic interfaces.
Jeff, You say “At this point, we do not believe the traffic passing interfaces of a BIG-IP can be exploited.”; Does this apply to the APM module as well given that those provide web services and serve web content through it’s service interface ?
Mitigation link giving Server Error?
Thanks. In the twitter link they claim that apache is in shadow group, this is not apparently the case on my F5 device. Can you provide clarity there too? Are these permissions some devices, all devices, is it revealed in /etc/group or somewhere else? Not that I want them running commands as apache, but I want to understand fully what I’m reading. Happy to take it to support ticket (already open) if you don’t want to discuss here.
Johny, a custom signature may be used in ASM to block Shellshock: https://auraredeye.zendesk.com/entries/56168065-Shellshock-CVE-2014-6271-Mitigation-Custom-ASM-signature This has been working well for us in production so far; we’ve blocked a lot of attempts particularly over the past 24 hours.
1) What about APM, used to check user certificates before passing the traffic on? That process is hosted by the F5 directly, and is exposed to anonymous users. 2) To all: … check your www logs for this string: () { - saw lots of attempts to install wow1 last night. If your F5 hosted server is at Bash enabled and unpatched… it may be already owned.
Hi Guys, Thanks all for all your posts and experiences on this issue thus far. Drawback question: What are these “*() {*;*}*” patterns or rather what makes you search for them? I’ve since checked the TCL site for a clue - but not quite there yet ;( https://www.tcl.tk/man/tcl8.4/TclCmd/string.htmM34 Are these REs? Anyone? Most (if not all) of my backend servers are windows, but still I’d rather use this to see what I get. So Im excited about this post really. Cheers
In reference to “At this point, we do not believe the traffic passing interfaces of a BIG-IP can be exploited. The attack will be passed to back end severs. We do not believe that the attack could exploit a BIG-IP directly through the traffic interfaces.” What is the situation with an iRule which performs a http redirect, or some other http response to a user request. Would this not also be vulnerable in the same way that a normal web server is?
When do we expect a path for our systems?!
Can you confirm how it is vulnerable to an authenticated user? I could not find any bash CGI scripts on our system.
Is the APM Logon page object in the Access Policy vulnerable to this attack?
Just seen that hotfix for 11.6 has now been uploaded and the solution article updated to reflect the new hotfix.
Hotfix-BIGIP-11.5.1.5.0.147-HF5 has been released to address these CVEs. It is available at http://downloads.f5.com SOL15629 will be republished to reflect this hotfix release shortly.
If the web GUI is vulnerable to an authenticated user, is it possible to reduce the exposure by disabling all user (except root/admin)?
Hello. I have a question in the following description. > BIG-IP does not contain any bash CGI programs, although it is possible that some CGI programs spawn subshells. What is the “subshells” ? I would like to know details of these shell.
