Customizing iApp Templates Question
Is there a way to update or create a new iApp template that will allow us to setup a base standard to start with for our new VIPs? For example, we want a particular cipher group to be enabled on every site built going forward. Or we want to disable persistence profiles on new sites? (2 examples that might be options).
I’m not finding an answer that says if this is possible. Thanks!
Yes! That is the whole point of iApps - you decide which part of the template is fixed and which part the user can change.
For instance, you could ensure that the user can only set an IP address and everything else is configured for them. That way you have consistent configuration, naming etc and you can leave the user to deploy the iApp ( via GUI, script, Ansible, BIG-IQ, portal etc ), knowing that they can’t break anything.
