Customize OIDs snmp_gtm monitor uses
I am wondering if it is possible to change the OID(s) the DNS SNMP monitor template gets and use the custom OID for current number of connections?
I have some appliances that we need want to DNS load balance and it has custom application level SNMP OID for current number of connections, which we would like to use in the limit settings and also for least connections load balancing method if possible. However it looks like you cannot change the OID it gets so for current connections it will only use .1.3.6.1.2.1.6.5.0
Thanks Tim
