Custom SMTP monitor
Can somebody point me to or tell me how I can make an smtp monitor? I built one, but for some reason it is not working.
Thanks!
Dave
You can use the existing SMTP monitor or a scripted monitor to check an SMTP pool. Here is the 9.4.3 config guide section on it (Click here).
You can get more detail by navigating to the monitor in the GUI and clicking on the Help tab. If it doesn’t work as you expect, you can enable debug as well.
Aaron
