Hi ,
Node showing inactive down when use the cutom monitor , but when i remove it and use TCP become active.
Please help with the HTTP monitor syntax , which should include : GET /sil/ HTTP/1.1 --> send request HTTP/1.1 200 OK ---> response
Hi ,
can you try this?
sol2167: Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
Hi, Please try with:
Send string: GET /sil/
Receive String:200 OK
For more info, Please do a curl (from bash shell) from F5 to node with /sil/ to confirm if it is giving valid output..
Regards, Hari
