yes, both loadbalancers will send the health checks to the server. They do this, so that both of them individually “know” the health status of the server. If the standby device would not know the health status in case of a failover event, it might send traffic to a server that id down.
For the “dynamic” URL I am not quite sure what you mean. Something like “/admin/status.php?appID=02”?
I think it will not differ from health checking a static URI. If you have a proper receive string it should work.
It depends on the value you are getting from this content check monitor. If it helps you to reliably determine the server state, you should discuss with the application team why the response takes so long. In the end it should be their interest as well that the BIG-IP can quickly check the state of the server and does not impose additional load on the server by querying dymanic URLs.
