Custom FTP Monitor
Hi all,
I want to create passive ftp load balancing on F5, but there is a problem about it.
If i create a custom monitor associated with ftp pool, monitor status is down and no traffic to the pool member. But i changed the health monitor to default tcp, pool & VIP are up and process the traffic.
Do you have any idea about why custom ftp monitor is not working ?
Regards. These are the custom ftp monitor settings ;
Name My_Ftp_Monitor Partition / Path Common Description Type FTP Parent Monitor ftp Configuration: Interval seconds Up Interval Time Until Up seconds Timeout seconds Manual Resume Yes No User Name Password Path / Filename Mode Alias Address * All Addresses Alias Service Port * All Ports Debug
You need to specify a path and filename.
The FTP monitor downloads the file to test the server is working.
Could give me an example about this ?
for example, my username is F5 and its password 123456Wq.
Regards.
The option Path / Filename must contain a file on your server the F5 can download. If its in a subdirectory then you must include that as well.
Just specify a very small file for it to download.
As i understand, my path must be like this, \192.168.1.58\ftp\F5\test.txt or only test.txt ?
Regards.
No no… the path should be unix style without the host pieces.
If the directory is ftp/F5 and the file is test.txt then you should use
/ftp/F5/test.txt
You should be able to test this yourself by logging into the FTP server and then
cd /ftp/F5
get test.txt
Ok Thanks for your help Kevin it works now,
Best Regards.
Only test.txt works as well :slight_smile:
Please ensure you tick the left of the post that provided the correct answer. This supports the volunteers who donate there time to help others on this site.
Thanks again,
Only test.txt it works for the Path option on the ftp customer monitor.
Regards.
