Is there a way in the iRules to read Current Connections on the particular node in the pool.
Like in the command line we can see the numbers in the following way …
[root@bigiptest:Active] config b node 172.31.1.109
NODE 172.31.1.109 UNCHECKED SESSIONS ENABLED
| conns (cur, max, limit, tot) = (13, 11, 0, 41)
| (pkts,bits) in = (1701, 1.453M), out = (2595, 28.59M)
| requests (total) = 41
Any hints / suggestions appreciated.
Thank you,
Shoaib
