Current connections on pool members
I am using the OID ltmPoolMemberStatServerCurConns(1.3.6.1.4.1.3375.2.2.5.4.3.1.11) to get the current connections on a pool member.The OID type is Counter64.Being a counter the value should go on increasing till it reaches max.value(i.e. value is accumilates on each polling.).But according to the values I get,I think the OID type is Gauge.
Whats the exact OID type??
Thanks,
Anuradha
IIRC all the CurConnections OID’s are in fact gauge.
H
