Hi, on v10 boxes I used to curl as below
curl -kv https://1.1.1.1:443 --cert /config/ssl/ssl.crt/mycert.crt --key /config/ssl/ssl.key/mycert.key
On v11 boxes the cert locations have obviously changed. Now I am struggling to recreate the curl command I need
I have this command
"curl -kv https://1.1.1.1:443 --cert /config/filestore/files_d/Common_d/certificate_d/\:Common\:mycert.crt_1_1 --key /config/filestore/files_d/Common_d/certificate_key_d/\:Common\:mycert.key_1_1
but it gives me the error : unable to use client certificate (no key found or wrong pass phrase?) * Closing connection 0 curl: (58) unable to use client certificate (no key found or wrong pass phrase?)
any help please ???
