cross platform migration issue
Hi, we want to migrate the config from iseries 4K to rseries 5k . The current software version on iseries is 13.x.. I tried to run bigip v15.x on rseries, then export the config from iseries and import it into rseries, but not successful, there were some errors. Can someone please advise how should I do to make the migration successful? Thanks in advance!
@Herman2024    I saw you had this same question posted in this thread,
What is the best practice for migrating from iseries to rseries? | DevCentral
was there something more that was needed from that post.
Thanks @Jmtaylor Former Member  for your advice. I asked before, but I saw someone used migration tool “Journey”. So a bit confused, should I use “Journey” or not? or just need to follow Former Member’s instructions. Please advise, thanks.
