crm2011 IFD with F5 APM
I tried to configured CRM 2011 , IFD with F5 APM .The web url is working fine , the issue is with the outlook plugin , the only documentation I find is CRM IFD with ADFS. We do not want to use ADFS .
F5 version is 10.2.4 . I know that the issue is with the authentication , the outlook plugin take the credential from windows . How can I have the credential pass to APM trough the outlook plugin.
thanks for you help.
Cindy
Can you please post links to the Microsoft documentation you’re reviewing in conjunction with this? Is this the case where you have CRM plugin in Outlook?
Basically , I follow the F5 deployement guide .http://www.f5.com/pdf/deployment-guides/dynamics-crm-2011-dg.pdf
Yes I have a look to this documentation by the configuration for Claim-based and IFD was not done at all the CRM server.In fact , this is where I’m blocked because on the procedure provide by microsoft it is design for ADFS .
Cindy
