Hi F5’ers,
I’d like to provision (some) local users even though Remote Authentication (using Radius) is provisioned.
F5 removed f5adduser (in 10.1.0), so, what’s the sanctioned alternative?
R’s, Alex.
Hi F5’ers,
R’s, Alex.
tmsh create /auth user role shell partition-access encrypted-password|password|prompt-for-password
“TMOS Management Guide for BIG-IP Systems” says: “Excluding the admin account, the entire set of standard user accounts that you create for BIG-IP system administrators must reside either locally on the BIG-IP system, or remotely on another type of authentication server.”
So, answer is - it can’t be done.
I am a bit confused now,in the top rectangle it is mentioned “can’t be done”.
The next rectangle provides a command for doing it ?
At this moment we are using version 12.1.3.7. Is there any change ?
We would like to use one extra local user on top of the remote users , to run a script for automated backup with keys.
Point is that we would like to take the server the initiative for the actions.
Anyone a suggestion ?
Hi Willy,
echo "username" >> /config/bigip/auth/localusers
sed -ri 's/(localonlyusers LT_STRING_LIST.*)"/\1 \\{username\\}"/' /etc/confpp.dat
Hello,
I have been looking for the Fallback to Local, in the above screen :
Is it possible that this option is not available in 12.1.3.7 ?
Available from v13.
Can you try this command?
modify /sys db systemauth.fallback.remotetolocal value true
I think, it is not possible in TACACS+ authentication on v12.1.x.
REF: myF5
Hello eaa,
Tried to modify the database parameter, and succeeded, but stil not able to create a local user. When I tried to create a user via cli, and then change the password, I still get the answer “Please change the password at the remote authentication server”. Also in the GUI there is no extra trace of a field that suggest a local user fallback. Maybe it is easier to plan a migration to version 13.
There is no fallback authentication.
Remove the Radius Authentication, create the users and config it again.
Thank you jaikumar_f5 and Dojs for your advice and effort. I will go for the update to a version above 12, it is than a standard feature.
Hi Enes,
these two commands work perfectly on our system.
But I noticed today (some weeks after implementation), that login with this local user is not possible anymore. I found out, that the changes to your mentioned files were gone. Are these settings maybe not reboot-safe or gets lost during a software update?
Can you please share some details here and is it possible to have these settings persistent?
Thank you!
Ciao Stefan ![]()
Hi Stefan,
The file /config/bigip/auth/localusers is auto-generated and should not be manually edited. After a system reboot it is expected that this configuration will be lost.
You can workaround this, to allow local and remote users to work at all times, by creating a startup script to add the local users to /config/bigip/auth/localusers on every reboot. However, this is not officially developed or supported by F5.
REF: myF5
Hi Enes,
sorry to bother you again, but this manual configurations gets lost even without touching or rebooting the BIG-IP. I had to re-enter both commands now twice within the last two days!
Any idea, which internal process removes this again? Is automated scripting (via cronjob) the only solution to have these entries permanent?
Thank you!
Ciao Stefan ![]()
That is the behavior of the box. Please refer the article K11333640.
To overcome this, you’ll have to create a startup script. Which would be on /config/startup.
Did you put the entries there & yet you see this issue ?
Also note this is pretty 10 year old thread, please open a new thread so it could be addressed properly.
/etc/cron.hourly/localUserInsert
#!/bin/bash
grep myUser /config/bigip/auth/localusers
if [ $? -eq 1 ]; then
echo myUser >> /config/bigip/auth/localusers
fi
And i’ll probably need to recreate it after every upgrade, but that’s not a big deal.
