Need some assistance with trying to configure an HTTPS custom Health monitor with a response of 200. Is it possible to use the whole url example below when creating the monitor on the LTM?
https monitor should look something like this. If pool member port is different, specify specific healthcheck port.
Send String: GET /apim/healthcheck HTTP/1.1\r\nHost: abc-def.staging.api.myest.com \r\nConnection: Close\r\n\r\n
Note: Host field could contain any string.
Receive String: Service is available
When you create the monitor, specify port 9005 in the “Alias Service Port” field.
