Is it possible to create SOA records on the GTM using the command line tmsh?
I can create a new WIP with the following:
tmsh
gtm
create wideip test.example.com pools add { Test_Pool }
However, the above commands use the GTM hostname for the SOA details such as ‘Master Server’ and ‘Email Contact’.
Instead of using the internal hostname, I want to create the SOA and NS records using a globally available domain name.
I can do this using Zonerunner from the web GUI but I want to be able to script it from the command line.
There is the following method that describes making modifications to the zonefile but I would prefer something from the tmsh that does not require manually freezing the zonefile:
James
There is currently no tmsh interface into the zonerunner/named/bind database. It is on a roadmap.
Hi, is this still on the roadmap or has this been released? I have been searching for an answer to this specific question and almost gave up until I found this thread. Thanks, Tom
Bump - I have the same question as Tom.
Gents, I know that this isn’t exactly what you’re looking for, but if you’re handy with iControl, you can add a second step to your plan and write/run a script that will change the SOA values for you. Check out Management::ResourceRecord::update_soa in the iControl wiki. I use scripts to add/delete/modify A and MX records now instead of the GUI.
Even with the initial development time for the scripts, I’ve saved countless hours by not having to use the GUI. I can provide code samples in Perl because that’s what I write in, but any other language and you’re on your own.
I would be interested in the perl scripts. Thanks!
Hello Faintly Lucky, can you please also let me see your perl scripts for managing DNS records over CLI?
I also wanted to control zonerunner. Specifically to create ‘static’ resource records like MX and TXT records. I stumbled across a little shell that seems to be what does the work for the configuration gui: zrsh. Variables, designated @VariableName@, are injected from my management tool- below are some examples of the format.
@Zone@ = 'example.com'
@EscapedZone@ = 'example\.com'
@RecordType@ = 'MX'
@DesiredRecords@ = '"external example.com. example.com. 3600 MX 10 smtp.example.com." "external example.com. example.com. 3600 MX 20 smtp1.example.com." "external example.com. example.com. 3600 MX 20 smtp2.example.com."'
@Authority@ = 'dns.example.com'
Here’s the script I ended up with:
!/bin/sh
ZoneFile=/tmp/newzone.external.@Zone@.
Zone=@Zone@
RecordType=@RecordType@
ZoneExists=0
DesiredRecords=(@DesiredRecords@)
Authority=@Authority@
Check if zone exists
echo "listzones" | zrsh | awk '{ print $2 }' | grep '^@EscapedZone@\.$' && ZoneExists=1
If zone didn't exist, create it
if [ $ZoneExists -eq 0 ]; then
Create Zone File Defaults
ISODate=`date +%Y%m%d`
cat << EOF > ${ZoneFile}
\$ORIGIN .
\$TTL 500 ; 8 minutes 20 seconds
${Zone}. IN SOA ${Authority}. hostmaster.${Zone}. (
${ISODate}01 ; serial (YYYYMMDDVV)
10800 ; refresh (3 hours)
3600 ; retry (1 hour)
604800 ; expire (1 week)
60 ; minimum (1 minute)
\$TTL 0 ; 0 seconds
NS ${Authority}.
\$TTL 3600 ; 1 hour
\$ORIGIN ${Zone}.
\$TTL 0 ; 0 seconds
EOF
echo "addZoneFile external @Zone@. master db.external.@Zone@. \"${ZoneFile}\"" | zrsh
rm -f ${ZoneFile}
fi
Strip existing static records
echo "displayzone @Zone@." | zrsh | grep '@RecordType@' | awk '{ cmd=sprintf("echo ''delrr external %s %s %s %s %s %s'' | zrsh ", $1, $1, $2, $4, $5, $6); system(cmd) }'
Set desired static records
for i in "${DesiredRecords[@]}"; do
echo "addrr $i" | zrsh;
done
Does anyone knows how to create a slave zone with zrsh ??
I have a hundreds of zone to create on my GTM as slave and I cannot resign myself to use the webUI !
Except this article, I found no other example of use of zrsh.
Same here, Faintly Lucky. Can you provide some perl samples?
Hey Lucky. Can you please provide your pearl script for managing the DNS records through CLI.
Gilles MOULIN did you find answer for your question?
no offically supported solution… only scripts.
It baffles me to this day how this has not been accomplished for going on 12+ years now. Especially with Automation. It is painful to use the iControl SOAP interface. It works, but we know it is being deprecated and what then … SSH again?
