Create PTR record for subnet
Hello, Am running version 12.1 and trying to create PTR record same as bind but it fail
Subnet: 192.168.1.1 records needed from 192.168.1.1 to 192.168.1.200 PTR => host-192.168.1.1.mycompany.com
Is it possible ?
using bind i could do this by using $GENERATE 1-200 $ PTR xxxx
Hi, You can try to do this using a script with zrsh:
!/bin/bash
for i in {1..200}
do
    echo "addRR external 1.168.192.in-addr.arpa. $i.1.168.192.in-addr.arpa. 500 PTR host-192.168.1.$i.mycompany.com." | zrsh
done
