create istats-trigger err
I create istats-trigger. It’s err.
Can someone help me? Thank you!
Hi 235,
the istats-key param must be a list item with at least two or a multitude of two fields…
create sys icall istats-trigger MyTriggerName event-name MyEventName istats-key "ltm.virtual VS_MyVirtual"
You may also check the following page for further information… DevCentral - An F5 Technical Community
Cheers, Kai
