We need to create IPv6 self-IPs in a non-default Route Domain, but we are getting the following error:
The vlan () for the specified self IP () must be one of the vlans in the associated route domain (0).
Seems the internal F5 logic interpret this as an IP-address from Route Domain 0, although we are in a partition which is mapped to Route Domain 4 (doing this, you normally don’t need to append the <%RD>). I verified this also on version 11.x and there it’s not an issue.
So is this a bug in version 10.2.3 or do I need to use a special format? Or isn’t this kind of setup supported in such an old version?
Thank you!
Ciao Stefan ![]()
