Create Friendly URL
Hi i have bigIp LTM, v11 OS
i want to create friendly URL instead typing big URL to access the application, i google and found the below html code
i just want to fit the following in the code:
my URL "http://10.10.1.10:4030/xyzbnhtyijhgful/ccvvddaa
i want to be http://10.10.1.10
how can write the code below to fit my requirments
switch -glob [string tolower [HTTP::uri]] {
“/ug/atl” {
HTTP::redirect “http://[HTTP::host]/a7391/users/0928179/events/live/release/20110403/regions.php?region=atl”
“/ug/sea” {
HTTP::redirect “http://[HTTP::host]/a2416/users/0622375/events/live/release/20100602/regions.php?region=sea”
}whenHTTP_REQUEST {
“/ug/atl” {
HTTP::redirect“http://[HTTP::host]/a7391/users/0928179/events/live/release/20110403/regions.php?region=atl”
“/ug/sea” {
HTTP::redirect“http://[HTTP::host]/a2416/users/0622375/events/live/release/20100602/regions.php?region=sea”
“/ug/atl” {
“/ug/sea” {
is 10.10.1.10:4030 virtual server? if so, is this what you are asking?
root@ve1100(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.19.252:80
    ip-protocol tcp
    mask 255.255.255.255
    profiles {
        http { }
        tcp { }
    rules {
        myrule
    vlans-disabled
root@ve1100(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
        switch [string tolower [HTTP::uri]] {
                "/" { HTTP::redirect "http://[HTTP::host]:4030/xyzbnhtyijhgful/ccvvddaa" }
                default {
                        HTTP::redirect "http://[HTTP::host]:4030[HTTP::uri]"
root@ve1100(Active)(/Common)(tmos) list ltm virtual bar2
ltm virtual bar2 {
    destination 172.28.19.252:4030
    ip-protocol tcp
    pool foo
    profiles {
        http { }
        tcp { }
    snat automap
    vlans-disabled
root@ve1100(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
[root@ve1100:Active] config  curl -I http://172.28.19.252
HTTP/1.0 302 Found
Location: http://172.28.19.252:4030/xyzbnhtyijhgful/ccvvddaa
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
[root@ve1100:Active] config  curl -I http://172.28.19.252/test
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
hi nitass,
yes 10.10.1.10 is VIP, i am not using CLI, i am using GUI, so i will create IRULE and put the code inside, and then go to virtual server proparties and add the irule,
so can you only the code
thanks again
hi nitass,
Any update
thanks
so can you only the codesorry i cannot catch what you want to say. what is the problem please?
hi,
i only want the html code that i should put in Irule, i am not familier with html language
the code is:
“/ug/atl” {
“/ug/sea” {
i want this code be sustituded with my input which is
Big URL : http://10.10.1.10:4030/xyzbnhtyijhgful/ccvvddaa
so that i can paste the code to the IRule and add it to VIP
thanks
the existing irule is applied to virtual server which is listening on port 4030, isn’t it?
if yes, can you try this one?
HTTP::redirect “”
“/ug/atl” {
HTTP::redirect “”
“/ug/sea” {
HTTP::redirect “”
this is my testing.
[root@ve1100:Active] config tmsh list ltm virtual bar
ltm virtual bar {
ip-protocol tcp
pool foo
profiles {
http { }
tcp { }
rules {
myrule
snat automap
vlans-disabled
[root@ve1100:Active] config tmsh list ltm rule myrule
ltm rule myrule {
HTTP::redirect “”
“/ug/atl” {
HTTP::redirect “”
“/ug/sea” {
HTTP::redirect “”
[root@ve1100:Active] config curl -I http://172.28.19.252:4030
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
let me know if i still misundertood what you are asking.
