CPU data, control and analytics plane utilization
Hi everyone,
Wondering if there is any “quick” way of extracting the CPU statistics for Data, Control and Analytics plane utilization via iControl ?
As far as I read,  Even-numbered logical cores (hyperthreads) are allocated to TMM, while odd numbered cores are available for other processes, while last core is used for analytics.
Do I need to do the math myself ?
That’s what I’m looking for as well. Have you found a solution?
Regards
When we execute a GET request to https://<BIG-IP-ADDRESS>/mgmt/tm/sys/host-info, the BIG-IP returns the information in JSON format.
I had created a Python script that wasn’t well formatted, but after adjusting a few things using AI, it seems to be working well now.
In the case of the .py script, I am separating even and odd CPUs in an attempt to visualize the data plane (even CPU) and control plane (odd CPU).
If it helps, here is the script.
For BD utilization I used this API but you can modify for your needs.
mgmt/tm/analytics/asm-cpu/report?options=view-by,virtual,measures,%7Bbd-cpu-utlization%7D
APIRef_tm_analytics
Thanks for the answer. Given the figure below, the average of odd-numbered CPUs represents the orange line (Control Plane), and the average of even-numbered CPUs represents the Data Plane, am I correct? What about Analysis Plane and System Average?
By the way, could you share the script or provide a link to access it?
Regards
Each CPU core is designated as data, control, or analytics, with all usage assigned to the core’s designated category. Each even-numbered core is designated as a data plane, each odd-numbered core as a control plane, and the highest odd-numbered core as an analytics plane.
Analytics plane-related processes are typically pinned to the highest odd-numbered core, and no control or analytics processes have access to the even-numbered cores. The processes pinned to the analytics plane usually consume all available CPU cycles when running, which is why they are assigned to a single specific core.
This division occurs when the CPU supports Hyper-Threading Technology (HT Technology). Overview of the HTSplit feature - https://my.f5.com/manage/s/article/K23505424
The BIG-IP VE system does not support this feature on generic hypervisors such as VMware ESX/i, where each vCPU will be allocated one TMM process.  https://my.f5.com/manage/s/article/K15468#tmsh
If you are seeing control plane and data plane CPU statistics in the dashboard, this is related to bug I id 969329 - https://my.f5.com/manage/s/article/K000132982
here is the script:
import requests
from requests.auth import HTTPBasicAuth
from tabulate import tabulate
import json
# BIG-IP
BIGIP_ADDRESS = "192.168.1.10"
USERNAME = "admin"
PASSWORD = "admin"
# disable warnings de SSL
requests.packages.urllib3.disable_warnings()
def get_cpu_stats():
    url = f"https://{BIGIP_ADDRESS}/mgmt/tm/sys/host-info"
    response = requests.get(url, auth=HTTPBasicAuth(USERNAME, PASSWORD), verify=False)
    if response.status_code == 200:
        data = response.json()
        cpu_info_path = data.get("entries", {}).get("https://localhost/mgmt/tm/sys/host-info/0", {}).get("nestedStats", {}).get("entries", {}).get("https://localhost/mgmt/tm/sys/hostInfo/0/cpuInfo", {}).get("nestedStats", {}).get("entries", {})
        odd_cpus = []
        even_cpus = []
        if cpu_info_path:
            for cpu_key, stats in cpu_info_path.items():
                cpu_id = stats["nestedStats"]["entries"].get("cpuId", {}).get("value")
                one_min_usage = stats["nestedStats"]["entries"].get("oneMinAvgUser", {}).get("value", "N/A")
                five_min_usage = stats["nestedStats"]["entries"].get("fiveMinAvgUser", {}).get("value", "N/A")
                if cpu_id % 2 == 0:
                    even_cpus.append([f"cpu{cpu_id}", one_min_usage, five_min_usage])
                else:
                    odd_cpus.append([f"cpu{cpu_id}", one_min_usage, five_min_usage])
            print("\nTable of Even CPUs:")
            print(tabulate(even_cpus, headers=["CPU", "1 Min Usage (%)", "5 Min Usage (%)"], tablefmt="pretty"))
            print("\nTable of Odd CPUs:")
            print(tabulate(odd_cpus, headers=["CPU", "1 Min Usage (%)", "5 Min Usage (%)"], tablefmt="pretty"))
        else:
            print("Unable to find CPU information in the returned JSON.")
    else:
        print(f"Failed to retrieve data: {response.status_code} - {response.text}")
get_cpu_stats()
Here is the script:
import requests
import json
# BIG-IP
BIGIP_ADDRESS = "192.168.1.19"
USERNAME = "admin"
PASSWORD = "admin"
        odd_cpus = []
        even_cpus = []
        if cpu_info_path:
                if cpu_id % 2 == 0:
                else:
        else:
    else:
get_cpu_stats()
For some reason, I’m unable to upload the .zip file here in the post. Here’s the link with the script.
