Correlation Id
Hi team,
I need to configure correlation id on my F5 ver 15.1.2.
I read on internet that is possible to do it by an irule thaat the moment,  I have not found.
I ask to the community if someone help me to do it.
Many thanks in advanced for your time.
Tks,
@unavailable if you can provide a bit more detail as to the exact data that you are trying to match I should be able to point you in the right direction. In most cases with HTTP/S traffic you just need to know the header you are looking for and pull the data out of it.
Hi Paulius,
many thanks for your reply.
At the moment the problem was resolved.
Many thanks again.
Rgds,
@unavailable  - how did you solve your problem? Curious if it is a solution a future user with the same question may be able to use.
Hello,
sorry for my delay to reply to you.
The customer has not preferred to install this feature.
Regards,
No worries, and no apology needed. :slightly_smiling_face:
Thanks for letting us know. May I ask what solution they went with?
