My hunch here would be that only one expr is needed. Also, and I missed this earlier, it’s more semantically correct to enclose the expressions in curly braces:
if { [expr {$v1 && $v2}] } { do something }
For a more detailed explanation of the expr syntax, I’d consult the tcl mothership:
% set param1 ""
% set param2 "null"
null
% put [expr { ($param1 ne "") || ($param2 ne "null") }]
0
% set param1 "test"
test
% set param2 "test"
test
1
% set param1 ""
% set param2 "null"
null
0
% set param1 "test"
test
% set param2 "test"
test
1
However I am receiving error when applying string operator
ne
to param and cookie values :
set param1 [URI::query [HTTP::uri] param1]
set cookie1 [HTTP::cookie value "cookie1"]
if { [expr { [expr { $param1 ne "" }] || [expr { $cookie1 ne "" }] } ] }
TCL error: /Common/myirule.conf - syntax error in expression " ne ": unexpected operator ne while executing "expr $param1 ne """
