Is it possible to copy a System-Supplied Attack Signature so that I can modify the copied signature and apply it to a custom Signature Set?
For example - While in staging, a System-Supplied Attack Signature gets tripped that turns out to be a false positive. We would still like to use the signature but just a customized version of it.
Also, where are the System-Supplied Attack Signatures stored on the F5?
I don’t think you will be able to view the content of the signatures. If you download the signature from downloads.f5.com, you will see that the signatures are encrypted. If you open the file with a zip software, and you find the file /RPMS/packages/current_sigfile.enc.
Not sure if the signatures are saved in the /usr/shared/ts, or in the mysql database. Anyway, if the file is encrypted in downloads.f5.com, I doubt it will be in clear text in the system. It will probably be in clear text in RAM, but that is too advanced to get.
F5 ASM stores the attack signatures in the internal MySQL database on the box.
There is an AskF5 KnowledgeBase solution SOL11680 which tells you how to dump the signatures from the database into a text file:
https://support.f5.com/kb/en-us/solutions/public/11000/600/sol11680.html?
However this command only dumps the signature ID and name, which is helpful if you want to compare two sets.
There is a little trick which allows you to actually extract the signature rules from the MySQL database if you add:
,PLC.NEGSIG_SIGNATURES.rule
just before the " from" command in the SQL query, so for example if you are a BIG-IP version 11.6 or higher you can run this command from the bash shell:
mysql -uasm -p`perl -I/ts/packages -MF5::Cfg -e 'print F5::Cfg::get_mysql_password()'` PLC -e "select PLC.NEGSIG_SETS.set_name,PLC.NEGSIG_SETS.set_id,PLC.NEGSIG_SIGNATURES.sig_id,
PLC.NEGSIG_SIGNATURES.sig_name,PLC.NEGSIG_SIGNATURES.rule from PLC.NEGSIG_SETS,
PLC.NEGSIG_SIGNATURES order by set_name,sig_id;" > /var/tmp/unit1_sig_sets.out
Then download this file from the box (e.g. using scp): /var/tmp/unit1_sig_sets.out
It will have the signature rules in it. The rules will be in standard ASM signature syntax described in the ASM guide here:
Hope this is useful (I get this question asked a lot).
Sam
I think the following query is more useful, as it lists which signatures are assigned to which signature set:
select
PLC.NEGSIG_SETS.set_name,PLC.NEGSIG_SET_SIGNATURES.set_id,
PLC.NEGSIG_SET_SIGNATURES.sig_id,PLC.NEGSIG_SIGNATURES.sig_name,
from
PLC.NEGSIG_SETS,PLC.NEGSIG_SIGNATURES,PLC.NEGSIG_SET_SIGNATURES
where
PLC.NEGSIG_SETS.set_id = PLC.NEGSIG_SET_SIGNATURES.set_id
and PLC.NEGSIG_SET_SIGNATURES.sig_id = PLC.NEGSIG_SIGNATURES.sig_id
order by
set_name,PLC.NEGSIG_SIGNATURES.sig_id ;"
> /var/tmp/device-signature-set.out
