Hi - well looks like my previous post got foobar’d somehow. Anyway thanks to willms & hoolio for their valuable input!!
I amended willms iRule slightly to:
when HTTP_RESPONSE {
set ASPID [findstr [HTTP::cookie names] “ASPSESSIONID” 0 20]
set debug “1”
if { $ASPID ne “” } {
if $debug {log local0. “ASPSESSIONID FOUND $ASPID”}
else {
if $debug {log local0. “ASPSESSIONID NOT FOUND”}
And the ltm log showed:
Jun 13 09:37:02 tmm tmm[952]: Rule ASPTEST : ASPSESSIONID NOT FOUND
Jun 13 09:37:03 tmm tmm[952]: Rule ASPTEST : ASPSESSIONID FOUND ASPSESSIONIDCCDATSAB
Jun 13 09:37:03 tmm tmm[952]: Rule ASPTEST : ASPSESSIONID FOUND ASPSESSIONIDCCDQCBQR
Jun 13 09:37:03 tmm tmm[952]: Rule ASPTEST : ASPSESSIONID FOUND ASPSESSIONIDQQSCDCQQ
Jun 13 09:37:03 tmm tmm[952]: Rule ASPTEST : ASPSESSIONID NOT FOUND
So we can capture the ASPSESSIONID info.
When we originally tried cookie insert the customer complained of some of his customers being logged out or told they were not logged in. A sympton of being re-load balanced and presenting an ASPSESSIONID that the server knew nothing about? Unfortunately we didn’t capture any tcpdump or header info at this stage so are going of memory!! But I agree with you hoolio the load balancing should work irrespective of what cookie the node might set.
The whole problem with failure is that I’ve not seen any, the site is VERY busy and tcpdumps are 100mb+ in less than a minute. And we rely on the customer getting complaints from his clients accessing the site. It’s all very messy to work out I’m afraid.
I also saw occassional issues with cookie persistence, so I use the session table to build the backend pool member reference from the sessionID. Maybe not the most efficient way, but I don’t have any issues with it.
if { [HTTP::cookie exists "ASPSESSIONID"] } {
if { [session lookup uie [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]] equals "" } {
session add uie $sessionID [IP::server_addr] 1800
log local0. "added server entry [session lookup uie [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]]\
for aspsessionID [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20] "
log local0. "existing server entry [session lookup uie [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]]\
for aspsessionID [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]"
if { !([session lookup uie [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]] equals "") } {
pool [LB::server pool] member [session lookup uie [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]]
log local0. "aspsessionID [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]
\sent to [session lookup uie [findstr [HTTP::cookie names] "ASPSESSIONID" 12 20]]"
log local0. "No aspsession ID, load balancing the connection..."
I noticed that SOL5714 (Click here) describes some possible reasons for cookie persist failures. I wonder if any of these issues may have affected your testing with cookie insert persistence…
Wouldn’t this look for a session table entry keyed on the 20 char following the string “ASPSESSIONID” in the list of cookie names… which would be the name of another cookie (or cookies), if any were listed after ASPSESSIONID, rather than the expected ASPSESSIONID cookie value itself…?
If so, that could certainly work well most of the time, but result in persistence failure if the list of cookies returned by the server ever changed.
To just extract the cookie values directly, adjusting your code accordingly, something more along the lines of:
set sessionID ""
set sessionID [HTTP::cookie ASPSESSIONID]
set persistTo [session lookup uie $sessionID]
if { $persistTo equals "" } {
log local0. "added server entry $persistTo for aspsessionID $sessionID"
log local0. "existing server entry $persistTo for aspsessionID $sessionID"
set sessionID ""
pool [LB::server pool] member $persistTo
log local0. "aspsessionID $sessionID sent to $persistTo"
I also dug up a a somewhat simpler version using “persist” instead of “session” I helped implement a while back & added it to the codeshare ()
IIS sets a cookie named ASPSESSIONID followed by 20 alpha characters. The 20 characters are dynamically generated based on the process ID of the IIS instance. So as long as the instance is up, the dynamic string will be the same. If the instance is restarted, the PID changes and consequently the dynamic string changes.
So you can persist off of the cookie name as a whole, or just the dynamic part of the string. There are a few advantages to using this method instead of the cookie value:
- the cookie name changes less frequently compared with the cookie value
- you don’t have to worry about the client changing the cookie value
- you only have one persistence record per web server--instead of one per client.
