Hi All,
Can you please let me know if we can bind the cookie persistency on the VIP running with Https port ? can you please let me know if it will work with out issues ?
Hi All,
It will only work if you also offload SSL at the VIP (apply a client SSL profile). The cookie persistence profile requires access to the clear text, unencrypted HTTP traffic.
Hi Kevin,
Thanks a lot for quick help. do you mean in the VIP i need to go to advanced and in SSL Profile (Client) and make the client ssl to selected ? before i enable cookie persistency on https VIP ?
I can see there is default client ssl which comes along with F5 .
waiting for your reply.
Yes, any client SSL profile applied to the VIP will provide SSL offload. This is the profile that you select in the “SSL Profile (Client)” section. Keep in mind a few things:
Once SSL is offloaded with the client SSL profile, the traffic is unencrypted. You can send that directly to your server pool on port 80 HTTP, or if necessary you can re-encrypt with a server SSL profile.
The client SSL profile is now the SSL server to the client. You’ll want to export the application server’s certificate and private key to the F5 and use those in a new client SSL profile. The built-in clientssl profile has a generic localhost.localdomain server certificate that will cause browsers to throw up a security warning.
