I have a new Virtual Server that I want to use persistence. Its fairly normal https traffic. One of the cookies that the servers send to the clients is ASP.NET_SessionId, which seems to be unique for each client logging in. I have tried creating a built-in cookie persistence profile - nothing seems to work. Intuitively, it seems as though HTTP-Cookie-Passive, & Cookie Name = ASP.NET_SessionId, should work.
I have success with UIE, using the following iRule, but can it be done with a built-in cookie profile?
set hsl [HSL::open -proto UDP -pool HIGH_SPEED_LOGGING]
set egains_token_value [HTTP::cookie value “ASP.NET_SessionId”]
if { [HTTP::cookie exists “ASP.NET_SessionId”] } {
if { $egains_token_value != "" } {
persist uie [HTTP::cookie "ASP.NET_SessionId"]
HSL::send $hsl "hsl_S3_vimportal_UIE [IP::client_addr] , persisting on ASP.NET_SessionId value = $egains_token_value pool_info: [LB::server]"
persist source_addr 1800
HSL::send $hsl "hsl_S3_vimportal_UIE [IP::client_addr] , source address persistence set for 1800 seconds"
when HTTP_REQUEST_RELEASE {
HSL::send $hsl "hsl_S3_vimportal_UIE server IP = [LB::server addr] , client IP = [IP::client_addr] ."
when HTTP_RESPONSE {
HSL::send $hsl “hsl_S3_vimportal_UIE [IP::client_addr] , TOP OF RESPONSE - ASP.NET_SessionId value = $egains_token_value, pool_info: [LB::server]”
