Cookie persistence stats?
I can monitor sr_addr persistence under statistics..how about cookie persistence?
thanks
What kind of stats are you looking for? LTM doesn’t store any persistence records for cookie insert persistence as the client holds the record.
Aaron
Hi Hoolio,
I know with sr_addr the F5 keeps a session state table, just wondering if there was a way to also keep track on cookie persistence.
You can use an iRule to log the persistence cookies:
http://devcentral.f5.com/wiki/default.aspx/iRules/Persistence\_Cookie\_Logger.html
Aaron
