Hi Folks,
We are looking to configure “Secure” and “HTTP Only” cookie persistence. We need to know how to configure it & apply with Virtual Server. We configured Cookie persistence with HTTP Cookie Insert method type but I believe this is not a right way to set secure & HTTP Only cookie. We are getting following output with current setting which is not right. Please advise how to set “Secure” and “HTTP Only”
Set-Cookie: BIGipServer_WEB_Servers_Pool=20293824.20480.0000; path=/
At a minimum you could do something like this:
when HTTP_RESPONSE {
foreach x [HTTP::cookie names] {
if { $x starts_with "BIGipServer" } {
HTTP::cookie remove $x
HTTP::cookie insert name $x value [HTTP::cookie $x] path "/" version 1
HTTP::cookie secure $x enable
HTTP::cookie httponly $x enable
Hi Kevin,
Many thanks indeed for your response.
Do I need to modify this or i can copy same in to irule text editor & apply it? Moreover how can I attach the irule with VS? Do I need to create universal persistence profile & call irule on it & then apply under VS default persistence profile or something else ? I am running BIG-IP version 11.4
Your prompt response highly appreciate.
Many thanks indeed for your help once again.
If you’re just trying to set the secure and httponly flags on the BIGipServer persistence cookie, then you can add this iRule as is to a virtual server. It works with a default cookie persistence profile. Copy the above iRule text to a new iRule (Local Traffic - iRules - Create). Apply the iRule to the virtual server along with the default “cookie” persistence profile.
Ahh. Minor oversight.
set ckname $x
set ckvalue [HTTP::cookie value $x]
HTTP::cookie insert name $ckname value $ckvalue path "/" version 1
HTTP::cookie secure $ckname enable
HTTP::cookie httponly $ckname enable
If applied to the virtual on which the cookie is inserted, you can get away with this (it takes advantage of the fact that “HTTP::header replace” affects only the last instance of a given header);-
if {[HTTP::cookie exists "cookiename"} {
HTTP::header replace Set-Cookie "[HTTP::header value Set-Cookie];HttpOnly;Secure"
I tried to use this and got the error: 01070151:3: Rule [secure_cookie] error: line 9: [wrong args] [HTTP::cookie httponly $ckname enable] I am clueless on irules and not sure how to fix it. Please advise…
What BIG-IP version are you on? The httponly option was added in v11.
