I’m having problem with cookie persistence.Currently we have this settings
ClientF5Server
Basically, we have client SSL profile and Server SSL profile. Both have certificate and key and the site is accessible. The problem is, i think cookie persistence is not working. My default is Cookie and fallback is Source persistence. I can see records of source persistence that leads to my suspicion that Cookie is not working.
I am not aware about fallback persistence but yes, if it is there then it will store the records i.e. when a connection is established from particular user, the IP address will be stored and whenever he/she will try establish again he will be directed to that particular node directly.
If I may clarify, the presence of source address persistence information is not indicative of anything “broken”. In fact it makes sense if you think about it. You want to do cookie persistence and use source address as a fallback if the cookie doesn’t appear in the client’s request. But if there’s no persistence information stored if/when the cookie doesn’t come, then it’s not going to help you. By enabling a fallback persistence mechanism in the VIP, the F5 will automatically start capturing affinity information, whether it’s ever used or not.
