Cookie Persistence doesn't work
Hi All,
I need a help here.
I have an issue with application where source tries to get a auth code from the server in one session and i believe again a different session is getting created for using the same auth code to do the api call.
In this case cookie persistence is not helping as second session goes to a different server instead of the server on which the auth code is generated.
Basically requirement is both connections should stick to same server which is not working due to two different sessions
Any suggestion is appreciated..
Can you use another kind of persistence like source address persistence?
Best Regards,
Oscar Pucheta
https://www.linkedin.com/in/npucheta/
