Cookie persistence 4.x to 10.x config conversion
I have a 4.x config with the following:
- pool A with cookie persistence
- pool A inserts cookie XPTO_A
pool poolA {
lb_method observed_member
persist cookie
cookie_mode insert
cookie_name XPTO_A
cookie_expiration 0d 00:04:00
member 1.1.1.10:80
- pool B with no persistence configured
pool poolB {
member 1.1.1.20:80
- rule calling pool A or poolB, depending on some “ifs”:
if (http_host == “xptoA.com”) {
use pool poolA
else if (http_host == “xptoB.com”) {
use pool poolB
So, we have here a rule that depending on the “ifs”, it does or does not do persistence via cookies.
Can you please help me and check to see if my below procedure is correct, in order to convert that config from 4.x to 10.x?
What I think it is the best conversion from 4.x config to 10.x:
1. configure the default persistence profile for the virtual server in question as cookie
2. configure the iRule to perform the persistence or not, based on the “ifs”:
set http_host_value [string tolower [HTTP::host]]
if {$http_host_value eq “xptoA.com”}
persist cookie insert “XPTO_A” “0d 00:04:00”
pool poolA
else if {$http_host_value eq “xptoB.com”}
persist none
pool poolB
Is it enough? Do you think it will work? It is the best way to do the conversion?
Thanks in advance.
JPL
[root@ve1023:Active] config  b virtual bar list
virtual bar {
   snat automap
   destination 172.28.65.152:http
   ip protocol tcp
   rules myrule
   persist cookie
   profiles {
      http {}
      tcp {}
[root@ve1023:Active] config  b rule myrule list
rule myrule {
        switch [string tolower [HTTP::host]] {
                "xptoa.com" {
                        persist cookie insert "XPTO_A" "0d 00:04:00"
                        pool poolA
                "xptob.com" {
                        persist none
                        pool poolB
[root@ve1023:Active] config  b pool poolA list
pool poolA {
   members 200.200.200.101:http {}
[root@ve1023:Active] config  b pool poolB list
pool poolB {
   members 74.125.235.48:http {}
[root@ve1023:Active] config  curl -I http://xptoA.com/
HTTP/1.1 200 OK
Date: Mon, 07 Nov 2011 18:44:10 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Mon, 07 Nov 2011 11:52:31 GMT
ETag: "4183e3-2a-b08f5dc0"
Accept-Ranges: bytes
Content-Length: 42
Connection: close
Content-Type: text/html; charset=UTF-8
Set-Cookie: XPTO_A=1707657416.20480.0000; expires=Mon, 07-Nov-2011 18:43:27 GMT; path=/
[root@ve1023:Active] config  curl -I http://xptoB.com/
HTTP/1.1 302 Found
Cache-Control: private
X-Content-Type-Options: nosniff
Date: Mon, 07 Nov 2011 18:44:15 GMT
Server: sffe
Content-Length: 219
X-XSS-Protection: 1; mode=block
Thanks nitass, you provided me the confirmation I needed.
Another way to do it could be creating a new persistence profile based on cookie persist and associate that new profile to the irule via persist command?
Example:
profile persist my_cookie_persist_profile {
defaults from cookie
mode cookie
cookie mode insert
cookie name “XPTO_A”
cookie expiration 0:04:00
override connection limit disable
and then in the irule:
pool poolA
