Cookie Persistence 101
I need to create a Virtual Server that uses cookie persistence. I am new to the subject as well as the F5 (but learning good stuff here!!!)
Is there a good primer doc on F5 that covers the basics, possibly with info on how to setup and configure?
Thanks!
Eric
See:
K83419154: Overview of cookie persistence
K6917: Overview of BIG-IP persistence cookie encoding
Generally speaking though, the built-in cookie persistence profile is more than adequate for most applications.
As a side note I higly recommend having the LTM and DNS Ops Guide handy if you are new to F5:
F5 LTM & DNS Ops Guide
