Cookie persistance
Hi Team,
We noticed a strange issue in our Enviornment.
Currently we enabled the default persistence as cookie. When we tried to access the application from different browser all the request are sending to only App server. Pasting below the jsession ID and cookie information. i could see the cookie information is same for all browser, Why it so? Finally I want to know when F5 will send the request to second APP server, does it require clearing cache on browser or F5 cookie?
IE:
mda_JSESSIONID=mOKmvioojyuMCkbprmyd698G; BIGipServerSAAS_MDA_POOL=3730919434.63530.0000
Chrome:
mda_JSESSIONID=YU4G9p8bcy0ZAZCL1KQA0cI3; BIGipServerSAAS_MDA_POOL=3730919434.63530.0000
Firefox:
BIGipServerSAAS_MDA_POOL=3730919434.63530.0000; mda_JSESSIONID=0Ddk1aKwg1CMNMXBlt-oMiiW
Thanks,
Akhi
Can anybody update on this.
-Akhilesh
Hi Akhilesh,
You confirm you persitance profil is set to cookie persistance. Can tell us what do you see in pool statistics ? Do you all request going to the same server or do you see stuffs to the second app server ?
What is your Load Balancing method ?
Take care
Matt
Yes, if i tried accessing application from different client IP then another APP server will start serving request.
But when i access from different browser from same client IP then request are going to only one App server and pool statistics will show traffic to only one APP box. i cleared my browser cache and accessed again and still the same app server is processing traffic. I tried after one hour and again same app server is serving request.
a) Why F5 cookie information is same for all browser?
thanks,
Akhi
Load balancing method- Round Robin
Default persistance- Cookie
Fall back persistance- Source address
Cookie value is the same because the member selected by LTM is the same.
Pleas try to :
- clear all cookies in your browsers
- check you LB methods (Round robin for ie)
- Check your persistance profiles (cookie insert par ie)
And make a test. Try without any persitance profile to test if load balancing methods works as well.
There is something in your configuration forcing all connections to server 1.
Disable the fallback persistance profile as well. It is the root cause I think.
is this helpful?
sol6917: Overview of BIG-IP persistence cookie encoding
Matt,
i just disabled fallback persistence profile and could see second app server start processing traffic. so My question why we need fallback persistence then? thanks for your help.
Also As I mentioned why cookie information is same for all browser from same client machine? how long will it keep this cookie information. currently i didn’t mentioned any time out value in my Virtual server configuration
-Akhi
Seems after disabling fallback persistence again the traffic are processed by one App server. please help me.
Can you post your Pool and Cookie persistence configurations please? tmsh list ltm pool ‘name’ and tmsh list ltm profiles persistence…
[root@MAIndia:Active:Standalone] config tmsh list ltm pool ‘SAAS_MDA_POOL’
ltm pool SAAS_MDA_POOL {
members {
10.80.97.221:irisa {
address 10.80.97.221
session monitor-enabled
state up
10.80.97.222:irisa {
address 10.80.97.222
state up
monitor http
ltm persistence cookie cookie {
always-send disabled
app-service none
cookie-name none
defaults-from none
description none
expiration 0
hash-length 0
hash-offset 0
match-across-pools disabled
match-across-services disabled
match-across-virtuals disabled
method insert
mirror disabled
override-connection-limit disabled
partition Common
timeout 180
steve,
I accessed my application from five browser and all are served by only one App server. currently i defined Round Robin mechanism in my F5 and still request are not distributed to all two back end Application servers.
is it any bug on F5 ?
Steve,
Do you need any more info, Can you please help me on this
-Akhilesh
Please make a test without any persistance profile on your pool in order to check if Round Robin LB methods works.
Please provide “list ltm virtual”
I accessed my application from five browser and all are served by only one App server. currently i defined Round Robin mechanism in my F5 and still request are not distributed to all two back end Application servers. is it cmp? if yes, can you try to disable cmp?
sol14248: Overview of Clustered Multi-Processing (11.0.0 - 11.2.x)
Try using Least Connections load balancing method.
Update please
