Hi All,
I have 2 virtual servers http_vs and https_vs on the same domain pointing to the same pool
our default web site is http but when it comes to login and purchase, users are redirected to https.
I want to achive cookie base session persitence with an idle timeout of 10 min.
Our application uses JSESSIONID as the cookie.
I tried with the available irule for jsessionid from here DevCentral - An F5 Technical Community. but this do not maintain session when switched from http to https.
I used even this irule DevCentral - An F5 Technical Community but issue is with application timeout.
So I modified the irule as below.
This logs information about the TCP connections on *both* sides of the full proxy
set client_remote “[IP::client_addr]:[TCP::client_port]”
set client_local “[IP::local_addr clientside]:[TCP::local_port clientside]”
Log details for the request
log local0. “| REQ | $client_remote | $client_local | server_local | server_remote | [HTTP::cookie value ISASESSIONID] | [HTTP::uri]”
if { [HTTP::cookie exists “ISASESSIONID”] } {
persist uie [HTTP::cookie value “ISASESSIONID”]
when HTTP_RESPONSE {
set server_remote “[IP::server_addr]:[TCP::server_port]”
set server_local “[IP::local_addr serverside]:[TCP::local_port serverside]”
if { ![HTTP::cookie exists “ISASESSIONID”] } {
if { [HTTP::cookie “JSESSIONID”] ne “” } {
set newCookie [HTTP::cookie value JSESSIONID]
HTTP::cookie insert name “ISASESSIONID” value $newCookie path /
persist add uie [HTTP::cookie value “ISASESSIONID”]
log local0. “| RES | $client_remote | $client_local | $server_local | $server_remote | [HTTP::cookie value ISASESSIONID]”
Can someone verify if this is the best way to achive cookie base persistence with application timeout?
