5100 Version 4.5.9 F5 is being replaced by 6900 Version 10.1.0 3341.0.
I have a few questions, answers will be appreciated.
1-) There is “snat timeout tcp 0” in old F5 and what should I use in new F5 in place of the command? I mean how should I configure snat tcp timeout infinite in new F5?
2-) I configured SNAT configuration in new F5 in place of the old configured snat as seen below. Used “snat automap” in virtual server configuration and created separate snat. Is the configuration correct?
3-)“service 38900 udp enable” in old conf. What can I use in new hw in place of this? There is “ip protocol tcp” in virtual server configuration, how can I enble both tcp and udp in virtual server configuration?
5100 F5 there is SNAT conf as below
snat timeout tcp 0
snat map { MMC_VLAN om rtcdb_traffic rtcdb_distrib rtcdb_om to auto unit 1
vlans admin disable
snat MMC_VLAN timeout tcp 7000
snat MMC_VLAN mirror enable
snat om timeout tcp 7000
snat om mirror enable
snat rtcdb_traffic mirror enable
snat rtcdb_distrib mirror enable
snat rtcdb_om timeout tcp 7000
virtual 10.4.104.5:38900 unit 1 {
use pool rtcdb_distribution_pool
mirror conn enable
vlans admin ext_om disable
6900 F5 I converted the 5100 conf to be seen as below; I used “snat automap” in virtual server configuration and created separate snat.
snat SNATMAP {
automap
snatpool none
origins default inet
vlans {
MMC_VLAN
om
rtcdb_distrib
rtcdb_om
rtcdb_traffic
} enable
virtual Distribution {
mirror enable
snat automap
destination 10.4.104.5:38900
ip protocol tcp
profiles tcp_0 {}
vlans {
MMC_VLAN
interlink
om
rtcdb_distrib
rtcdb_om
rtcdb_traffic
} enable
virtual NSTraffic-1 {
mirror enable
snat automap
pool rtcdb_ns_traffic_pool
destination 192.168.101.7:11389
ip protocol tcp
profiles tcp_7000 {}
vlans {
interlink
om
rtcdb_distrib
rtcdb_om
rtcdb_traffic
} enable
mirror enable
snat automap
ip protocol tcp
profiles tcp_0 {}
vlans {
MMC_VLAN
interlink
om
rtcdb_distrib
rtcdb_om
rtcdb_traffic
} enable
