if standby unit failed to detect active unit for X seconds on Newtork cable on HA vlan , Fail-over will happen
What is default for this X & how to change it ?
also what is the same fro Hardware failover ?
What is default for this X & how to change it ?i understand it is Failover.NetTimeoutSec db variable which is 3 seconds by default.
sol2397: Comparison of serial failover and network failover features
also what is the same fro Hardware failover ?i do not think so. please review sol2397 above.
Thx , the link mentioned default for Network failover , it didnot mentioned abou default value for serial failover
Also how can i cahnge these values from GUI ( or CI if GUI is not possible )
how can i cahnge these values from GUI ( or CI if GUI is not possible ) i do not think it is configurable.
