Hi guys,
I have a strange issue going on a production F5. This iRule was running fine until people started to report that the Pool members are not getting any traffic. I quickly removed the following iRule and traffic started to flow to the pool members. Apparently the issue is with the HTTP_REQUEST clause, but I cannot find any clue why it stops sending traffic at all:
Below the code:
Code
This IRULE inspects the incoming session parameters and finds the CN number of the SSL certificate
it is possible that a SSL session is continued, so the IRULE will look at HTTP session start.
ensure cn is properly initialized. "when CLIENT_ACCEPTED" is triggered when the 3-way TCP handshake is completed
the CN is the critical info which contains a serial number of the authenticated device...
Lines that are commented out with double are actual comments
Lines that are commented out with single are logging/debugging commands that can be enabled on demand
when CLIENT_ACCEPTED {
Choose 1 to log DEBUG info
static::CRL_DEBUG_LOCAL 1 enables logging to local log file /var/log/ltm
static::CRL_DEBUG_REMOTE 1 enables logging to HSL server
Use local DEBUG ONLY in lab tests - it will NOT scale well for production use
set static::XDEV_DEBUG_LOCAL 1
set static::CRL_DEBUG_REMOTE 1
start with cleaning the cn value
set cn "-"
Set remote logging server pool (must be created via GUI first)
set hsl_pool "HSL_pool"
initiate handler to syslog publisher for HighSpeed logging
set hsl [HSL::open -proto TCP -pool $hsl_pool]
update cn in case a session was picked up
when CLIENTSSL_CLIENTHELLO {
set connection "[IP::client_addr]:[TCP::client_port]->[IP::local_addr]:[TCP::local_port] sslsessionid=[SSL::sessionid]"
if { [SSL::cert count] > 0 } {
Save the first cert in the client request
the client sends a client certificate together with a client intermediate certificate. Client certificate must come first.
set cert [SSL::cert 0]
Save the cert fields to a list
set fields [X509::cert_fields $cert [SSL::verify_result] subject]
update the cn
set cn [findstr [lindex $fields 3] "CN=" 3 ","]
if { $static::XDEV_DEBUG_LOCAL } { log local0. "$connection; client hello cn=$cn"}
if { $static::XDEV_DEBUG_REMOTE } { HSL::send $hsl "$connection; client hello cn=$cn"}
determine and save the CN when a client presented a cert after it was requested/required
when CLIENTSSL_CLIENTCERT {
check if there is at least one certificate in the presented cert. chain
log local0. " count = [SSL::cert count]"
set vfy [SSL::verify_result]
if { $vfy != 0 } {
if { $static::XDEV_DEBUG_LOCAL } { log local0. "Client certificate verification result - $vfy : [X509::verify_cert_error_string $vfy]"}
if { $static::XDEV_DEBUG_REMOTE } { HSL::send $hsl "Client certificate verification result - $vfy : [X509::verify_cert_error_string $vfy]"}
update the cn
if { $static::XDEV_DEBUG_LOCAL } { log local0. "$connection handshake cn=$cn"}
if { $static::XDEV_DEBUG_REMOTE } { HSL::send $hsl "$connection handshake cn=$cn"}
write CN information from client certificate into X-DEV header
HTTP::header insert "X-dev" $cn
if { $static::XDEV_DEBUG_LOCAL } { log local0. "INSERTED XDEV-HEADER for client [IP::client_addr]: $cn"}
if { $static::XDEV_DEBUG_REMOTE } { HSL::send $hsl "INSERTED XDEV-HEADER for client [IP::client_addr]: $cn"}
