What are the difference with entries in the connection table between version 9.4.6 and 10.2Hf2 After upgrade to version 10.2Hf2 we are missing 8000 entries.
Thanks in advance Jaap
Hi Jaap,
Can you clarify what you’re seeing in 10.2 that’s different? How are you viewing the connection table entries?
Thanks, Aaron
Aaron,
We are using the commando b conn show all.
i thought 7,037 is maximum.
sol6573: The bigpipe conn command displays a maximum of 7,037 connections
