Attempted to access a BIG-IP instance using the Java API. The code used for the POC is the sample Codeshare script - https://devcentral.f5.com/codeshare/java-system-info. We get thrown the following exception:
AxisFault faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException faultSubcode: faultString: java.net.ConnectException: Connection refused: connect faultActor: faultNode: faultDetail: {http://xml.apache.org/axis/}stackTrace:java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.connect0(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source) at java.net.AbstractPlainSocketImpl.doConnect(Unknown Source) at java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source) at java.net.AbstractPlainSocketImpl.connect(Unknown Source) at java.net.PlainSocketImpl.connect(Unknown Source) at java.net.SocksSocketImpl.connect(Unknown Source) at java.net.Socket.connect(Unknown Source) at sun.security.ssl.SSLSocketImpl.connect(Unknown Source) at sun.security.ssl.SSLSocketImpl.(Unknown Source) at sun.security.ssl.SSLSocketFactoryImpl.createSocket(Unknown Source) at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:118) at org.apache.axis.transport.http.HTTPSender.getSocket(HTTPSender.java:191) at org.apache.axis.transport.http.HTTPSender.writeToSocket(HTTPSender.java:404) at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:138) at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32) at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) at org.apache.axis.client.AxisClient.invoke(AxisClient.java:165) at org.apache.axis.client.Call.invokeEngine(Call.java:2784) at org.apache.axis.client.Call.invoke(Call.java:2767) at org.apache.axis.client.Call.invoke(Call.java:2443) at org.apache.axis.client.Call.invoke(Call.java:2366) at org.apache.axis.client.Call.invoke(Call.java:1812) at iControl.SystemSystemInfoBindingStub.get_system_information(SystemSystemInfoBindingStub.java:1793) at SystemInfo.getSystemInformation(SystemInfo.java:24) at SystemInfo.Run(SystemInfo.java:18) at SystemInfo.main(SystemInfo.java:67)
Is there something that is being overlooked?
