I deployed the Exchange CAS 2013 configuration with the iApp 1.3.0; the configuration is optimized by default but for example when I try to join my OWA VIP since, the web browser try to load the page (Website found, waiting for reply) but finally the connection fails. The server is ok because is ready when I join it directly. Yet, I see the flow from client to server behind the VIP and the server responds to the client with tcpdump.
Another thing I have a second configuration (manual no iapp) where I just configured a HTTPS VIP with a pool which contains the same server (but not ssl client profile, http profile, iRule combined https etc..) and is also ready !
My iApp config.: CAS2013 / Incoming client traffic : encrypted / Re-encrypt to CAS: No (ssl offload) / SSL profile with good certificate an key associate / LAN optimized client profil / Different subnet between VS & CAS / Use Big-IP defautl GW / Single IP for all connections / Same set of CAS for services / One FQDN
So there are: http profil, webacceleration caching profil, oneconnect profil, ssl client profil, irule for combined pool
Some idea why is not ready with iapp configuration ? I think SSL offload is not configured on server but when i deactivate all profil is not ready also …
