connection limit on VS and redirect page
Hi All,
I’m trying to make a irule for connection limit on VS and redirect page.
in example.
when the connection limit is a 1000 on Virtaul Server . if the connection of 1001 on virtaul server is coming , that would redirect to redirction page.
do you have some ideas?
Many thanks in advance.
On the VS configuration there is a MAX connection limit,
As you are using http, a http_profile could specify a fallback page URL. This is normally used for when the pool is unavailable, but I’m not sure if it would trigger in this case; try it and see.
Failing this, with a bit of research the VS connection limit variable and current connections variable may be available to reference insid ethe iRule: (PSEUDO CODE BELOW, THIS IS NOT TCL)
if [ $CURRENT_CONS > $VS_CONN_LIMIT]
HTTP::redirect https://my.domain/too\_many\_connections\_page.html
return
or similar?
these might be useful.
v10.1 - The table Command - Examples by Spark
iRule::ology - Table Based Rate Limiting by Colin
