I cant understand how do I get rid of this message. This error causes https webpage errors. Not all the time but about 30% of all connections.
After upgrading SSL cert to ECC cert and ECDSA key, then problems begun.
F5 debug log:
Connection error: ssl_select_suite:5745: TLS_FALLBACK_SCSV with a lower protocol (86)
Browser error ( latest Chrome and Opera ):
A secure connection cannot be established because this site uses an unsupported protocol.
ssl options
No SSLv2 No SSLv3
Ciphers are ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-CBC-SHA:ECDHE-RSA-AES256-CBC-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA:AES256-SHA:ECDHE-RSA-DES-CBC3-SHA:DES-CBC3-SHA:!RC4
ECC cert and ecdsa key are described in ssl-client, also RSA key and cert
Hi Mihkel ,
Can you please see which cipher suites are sent by client to the F5 when the issue happens and check in wireshark . above ciphers are of F5 client ssl or client ?
Client sends Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b)
Ciphers above are F5 client ssl ciphers.
Thanks for your time
Hi, Client sends Cipher Suite: TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b) Ciphers above are F5 client ssl ciphers. Thanks for your time
is the client also sending tls fallback cipher ? Which ssl version are enabled on client and servre ?
no its not sending fallback cipher.
Server enabled: TLSv1, TLSv1.1, TLSv1.2 Client: Same as server
no its not sending fallback cipher. Server enabled: TLSv1, TLSv1.1, TLSv1.2 Client: Same as server
I just tested and with RSA cert and RSA key, all works fine. Seems F5 has TLS problem with elliptic curve certs and ECC ciphers
Good to know issue is resolved . but not sure if F5 is to be blamed Mikel .. if you have support F5 , you can confirm with F5 . Regards
