Connection error: ssl_passthru:4015: not SSL (40)
Hi DC,
I am getting the following error for every second.
Sep 29 05:41:31 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:33 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:34 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:35 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:36 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:38 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:39 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:40 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:41 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:43 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:44 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:45 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:46 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:48 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:49 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:50 warning tmm[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:51 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:53 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:54 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40) Sep 29 05:41:55 warning tmm1[12472]: 01260009:4: Connection error: ssl_passthru:4015: not SSL (40)
I believe it is coming when non ssl traffic is sent to a Virtual Server that has a clientssl profile. If this is correct how can we find out that Virtual Server ?
Thanks in advance.
Can you search for the below in your /var/log/ltm
less /var/log/ltm* | grep "SSL Handshake failed for"
This might tell you which VS its failing for. This is an info log, so by default this would be captured in your ltm log file. In the event you dont find the correct VS, then you need to increase the SSL debug logging.
tmsh modify /sys db log.ssl.level value debug
