conncurrnet connection information LTMs
Hey guys,
what is the best to get the number of conncurrent network connections on LTM for license purposes ?
You talking APM? (Sessions). Or connections per second on SSL offload?
(Either way you can get the numbers from either tmsh or snmp. Or iControl (REST or SOAP). You just have to get the numbers from a different place, depending on what you actually want…
H
sessions per second ssl offload. We are currently seeking a quote for the apm license and our architect was looking for that info.
Would tmsh show sys traffic work ?
output of command:
ClientSide Traffic Total Last 5 sec Last 1 min Last 5 min (avg/sec) (avg/sec) (avg/sec) Bits In 25.8T 843.3K 1.1M 1.1M Bits Out 551.4T 10.4M 20.8M 21.9M Packets In 37.0G 968 1.4K 1.5K Packets Out 56.1G 1.2K 2.2K 2.2K Current Connections 1.0K - - - Maximum Connections 3.0K - - - Total Connections 1.4G 62 58 57
ServerSide Traffic Total Last 5 sec Last 1 min Last 5 min (avg/sec) (avg/sec) (avg/sec) Bits In 24.4T 853.0K 1.0M 1.0M Bits Out 547.7T 12.4M 20.8M 21.5M Packets In 35.9G 1.0K 1.4K 1.4K Packets Out 56.2G 1.4K 2.1K 2.2K Current Connections 992 - - - Maximum Connections 2.5K - - - Total Connections 1.4G 59 57 56
what are some good free resources/link to get skilled up on with APM if training is’nt an option
Thanks again
Just take the total number of connections every 60 seconds. Then calculate the difference between consecutive readings and divide by 60. That’s connections per second. You’ll need your SSL license to be about twice your PEAK connections per second (averaged over 60 second period as above).
For APM. Grab a lab edition (US$100) and run one up. Best education you can get is doing it yourself and learning from your mistakes.
H
If you’re looking for APM CCU (concurrent user) licensing information, SOL13267 talks about what actually consumes a license (since not every connection does).
After looking at multiple ways of looking for the actual CCU license counts, we ended up with this command,
echo -e 'get tmm.license.global_connectivity\r' | nc 127.1.1.2 11211
. You’ll get a response that looks a little bit like the following. The second line contains the current count of utilized APM licenses.
VALUE tmm.license.global_connectivity 0 2
37
END
There is an article that was related to this here. It’s in French, and focused on logging during the APM session start flow, but it’s worth looking over.
show sys traffic
should I go off the current connections data or total connections ? I am also assuming that max connections the limit for the license when doing the show sys connections. Thanks again
